I have a 2019 Yukon XL Denali. I'm having trouble with the keyless remote. The lock/unlock function only works intermittently when I press the button on the door handle. I've changed the battery in my #1 remote. It didn't help. I also tried the #2 remote with the same result. The remote start and lock/unlock buttons on the remotes work perfectly. Only the keyless entry is a problem.
The Yukon is still under the bumper to bumper warranty. I have an appointment with the dealer. Before I take the time. I'm just wondering if there's anything else I can check. I had the windshield replaced recently. Could that be an issue? Where is the antenna for the keyless entry located?
Thanks.
Thanks, Mike. I have a service appointment on Monday. This will be handy if the dealer says he can’t find the problem.
Update: My dealer called and said they found the service bulletin I mentioned. They don't have the part, but will keep the car overnight and replace the antenna amplifier tomorrow.
As a bonus, it was also time for an oil change. The mechanic found a leaking oil line. That will be replaced under the warranty.
All will be well again tomorrow.
On 12/28/2020 at 10:36 AM, Mikey999 said:
Wow that  was a good find on the oil line. Good service from your dealer going above and beyond.
They’ve been pretty good to me over the years. I go there for oil changes because they charge about the same amount as it would cost me to buy materials and do it myself.
I had the defective vacuum pump problem with my 15 Sierra, before it became a recall. The cost was going to be about $1,000. They contacted GM and got some help for me. The cost came down to $200.
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
