Hi All,
I have a 2017 GMC Sierra Denali 1500 pickup that's giving me issues with the fuel gauge.  When I fill up with gas it only goes up to about the 3/4 mark.  This isn't the first time this the first time this issue has come up for me.  Back in February it did the same thing.  Took it to the dealership & they said that this is a very common issue that happens due to the use of additives in the fuel used in winter fuel blends.  So common that they were getting 3 to 5 vehicles in per day with this issue.  They inspected the truck and then ordered and replaced the fuel sending unit.  This fixed the problem for me at that time but it's back.
Same as last winter, last time I filled up I put 22.3 gallons & the light was not on yet but only got to about 3/4 of a tank on the gauge.  After driving a few miles it creeped up towards towards the full line, but not quite get there.  Then the next time I start the truck it's back down just above the 3/4 tank line even though I've only driven about 10 miles since that last fill up.  It then reads much lower than expected for the remainder of the tank.  For example I've only driven 140 miles of mostly hwy miles on my current tank of gas and already down to the 1/4 tank mark on the fuel gauge. When the gauge is operating normally I'd still be well above the 1/2 tank line at this point.
Who else has had this issue and what'd you do to fix it?
The other concern I have now is that I've had my truck for more than 3 years now & have about 38,000 miles on it.  Concerned that the dealership & GM won't cover the costs of fixing this due to it being past the warranty period even though they'd be fixing an issue that was supposed to fixed less than a year ago.
Edited by steve76t
2 hours ago, steve76t said:
Hi All,
Have you let the dealership know the issue is back?
I believe parts replaced under warranty have their own 12/12000 warranty, so if it is what is failing, it should be covered. But I would check to make sure with your dealer.
  • Thanks 1
Not just yet...  Just started back up again with the last two fill ups, the last one being worse the than the previous fill up.  Going to see what my next fill up later this week looks like before calling the dealership again.
I would just let them know, so they can put it the service records on the truck, better safe than sorry later when you have even more miles on the truck.
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 705 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
