Hi all
Installing Airlift air bags and the auto level compressor.2020 RST Duramax 4 wd  Looking for some input on what fuse to piggy back for an" on with ignition" power in the under the hood fuse block . Small trailer with a toy hauler in the front I get 900 lbs. tongue weight. I do not like the sag when fully loaded.
Thanks
Kirk
Kirk, Looking for the same thing.  Did you find a suitable fuse to tap into?  If so, I would love to know which.
Hi Xterrable
I have it in fuse # 40 10 amp using a piggy back fuse holder. I have not had a chance to properly test this location as the stainless steel line from Air Lift was bad and i am waiting on a new one. But that location is hot when the engine is started and doesn't need the transmission to be in drive.
Hope this helps
Kirk
