I have a 2020 Z71 diesel, My Boyfriend has a 2020 trailboss Custom. I'm Trying to buy the same center console that is in my truck for his trailboss. Mine has the flip lid with all the electronic plug ins and the under the seat storage compartment. Where can i get one for his truck? or maybe what is it called exactly so i can look for one? thanks in advance for all the help!
Try here...
https://www.gmpartsdirect.com
