If you have a 3.0 Duramax and it bounces around like a jackrabbit, go get new shocks.  I cant get Bilstiens since they are backordered and I cant wait till mid-February so I had some Fox brand shocks installed on all 4 corners.  Problem solved.  Man I'm happy as hell!
Is it a z71
Sent from my moto z4 using Tapatalk
12 minutes ago, BurnsMax said:
Try shock warehouse.com.  Mine came in a week but that was in the summer.  I went with the Bilstein 5100s
Lol.
Already done. Happy with the new setup.
17 minutes ago, Justin Vaughn said:
which fox did you go with ?  small delta in price there lol.you should be happy for that much change.
Front- 985-62-012
Rear - 985-24-209
1 minute ago, It's Tim said:
Placebo effect
So you're suggesting my stock shocks and fox are equivalent?   Or fox vs bilstein?
Glad to see this post, thank you. I have a similar setup (stock) and it's not "bouncy" but I would like to see some improvement. I was waiting to upgrade wheels and tires first.
3 hours ago, It's Tim said:
Placebo effect
Like installing a throttle body spacer.  Good 'ol butt dyno/ride sensor.  ?
aaah ok.  looks like you dont know.   Now it makes sense.
Original shocks lick balls.  Bounce around like a car with 300k miles on it.  Even worse towing a 33' travel trailer.   Glad it made a big difference vs stock junk ?
  • Haha 2
    • I have 2 choices.
