My 2008 chevy Avalanche ltz won't start sometime and when it does the gages and door locks go crazy. I have saw videos on YouTube on how to fix the problem but still dont work. I have replaced the battery, alternator, starter,ignition switch,  negative battery cable,  pcm, bcm, added extra ground wire to the ground strap from the motor, replaced fuse box inside the truck, replaced all fuse in junction box under the hood, replaced ground wire from the hood. Still same problems. A friend told me to try replacing positive cable and cam shaft sensor. Need help asap
Holy parts cannon. Stop replacing parts on that one. You need to check over EVERY ground on the vehicle, specifically the ones around the engine and under the cab. I would remove and clean every single ground connection. From there you'll need to inspect wiring harnesses for chaffing, melting, or complete rub-through. From there check every connector - start with the easy ones, and work your way toward the harder ones. I'm betting there's either a bad or missing ground, green pus in a connector, or a broken wire hidden inside intact insulation.
Check the ECM and BCM for powers and grounds - make sure they're all good right to the modules. Make sure no pins got bent during the BCM swap, and make sure there are no bent pins on the ECM connection as well. This one will try your patience, but without service info, this is the only way to get it done.
Does this vehicle have any aftermarket remote start or alarms added to it? First place I would be looking at  if anything was added on. They are usually poorly installed and the components are garbage.
^^^ Yep, what Mike said. ^^^
There a couple of older bulletins similar to what your describing. I can't figure out how to send a link but the actual bulletins are PIT4730B,document ID #4902455 and the other one is 08-07-30-021H document ID#4213654. They have a lot of good information in them about no start conditions and door locks cycling with gauge cluster problems. Hope you can get access to them. Don't throw anymore parts at this. Its probably a backed out terminal or an intermittent short to ground taking down the high speed lan. Good luck.
    • I've installed cheap eBay new aftermarket digitizers before.  They work.  Did a bunch of Cadillac CUE (aka Cadillac's MyLink) for someone years ago.  They all worked fine after the repair.    That number 22740886, that is a component part # for GM.  You can use it to search, but its not something that's obtainable at the dealer level.     So pretty much any of these will work - 2015 Colorado Digitizer for sale | eBay
    • Black bumper and the later years Z-71 style color matched grille.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • // Thank you, also for your  response. More information is always good. This 2013 GMC is most likely my 'forever truck"-I'm 77 and retired...and truck only has 42K on it-very clean-so I try to keep it that way.  Tks again for your  response- glenn
