i'm new to the forums , ive searched all over and cant find what im looking for
my truck is a 2015 silverado LT 1500
no idea what mirrors it had on it , someone installed towing mirrors and the functions would not work correctly
passenger would only go up and down when using the left to right arrows or vice versa
driver only goes up and down
the pins are not in the correct place for the towing mirrors
truck harness has 9 pins
mirrors have 9 pins
so i took all the pins out from the factory harness on the truck and started testing with voltmeter
but cant get them to work
anyone have a color diagram on the factory plug to see what does what ?
i just want the mirror to move up and down, and side to side for now
ill worry about the other features later on , ive read you have to add 3 wires to the harness or buy PGAMBOA harness
As far as the old mirrors, look in your glovebox at the RPO codes. Should be DL8 if you have an LT. PGamboa is def the man to get your mirrors working 100%. Do you know if they’re oem or aftermarket tow mirrors?
DL8 , I try sending phill a PM but either hes not accepting any or the system doesn't let me because i'm new
these definitely look aftermarket judging by the color of the wires
@pgamboa is a super busy man!  Lol. He’ll get back to you and get you all squared away when he gets a minute. I figured they were aftermarket by the sharply squared connector. If you get a chance, you might be able to unbolt the mirror and see if there’s any markings on the backside of the housing. I wouldn’t be surprised though if he could guess them by looking at the connector with his mental database.
I saw this thread earlier when it was posted, but been super slammed with orders.  This is most definitely an aftermarket mirror based on this wire colors, sleeving, and overall finish of the wire.  Can you explain the pink wire that is out?  Was it like this or did you do this?
The middle row of pins (5 pins total) are your circuits for - Mirror Heat (Pin #8), Mirror Motor Up/Down Control (Pin #9), Mirror Motor Left/Right Control (Pin #10), Ground (Pin #11), Driver Mirror Motor Common (Pin # 12).  The empty slot is position #7 which is not used (for mirror memory) in this mirror.
The top (can only see a red wire in your pic) and the bottom row (all empty), are usually the lighting circuits.
What I would do - is disconnect the passenger mirror and focus on driver only mirror first.  With the driver mirror only plugged in, what happens?  While you're at it, can you confirm the part # of the switch you are using?
Let's keep the troubleshooting here, so it will be visible to everyone.
I have seen aftermarket mirrors that have their motor wires flipped... so this will take some troubleshooting.
i broke the pink wire , rookie mistake , was going to re-pin the mirror harness and then saw everyone re-pining the truck harness , didn't know you had to lift the white tab on the plug , was doing it the old school way lifting the plastic tab next to the pin with a small tiny flat screw driver pulled to hard on the cable , no big deal , easy fix
on the mirror harness passenger side
pink = glass turn signal
blue = side cargo lamp
red = running light front of mirror
black i assume is the heated mirror or ground
on the truck harness passenger side
black i assume is heated or ground from what i read
green with black line  = mirror right
white wire =  left
yellow with brown line = UP
well i got it to work correctly , up down and side to side
and brown with orange stripe is the heating element +
now where do the other 3 go ? or what did they do on the DL8 ? i assume black goes with black ?
and the brown goes with the grey i have left in the middle row ? of the mirror harness
on the truck harness i have left
black with blue line
white with green line
blue with grey line
Edited by MIKE-HKS
Phil,
Are you still recommending Trail ridge mirrors?
Sent from my Pixel 3 using Tapatalk
Phil,
Been pretty solid mirrors.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
