My truck: 2015 GMC Sierra 1500 SLT.
I am getting ready to replace the seat heaters on both seats, seat bottoms only. While looking for the parts, I watched a youtube video that the gentleman included the part number he used, he was working on a "16 Sierra 3500, ventilated bucket seats, looks just like my '15 Sierra 1500. I went looking for that part number, it seems that there is a different part number for the 1500 compared to the same option 2500 and 3500. I was curious if someone could enlighten me on really what the difference is.
What I have found from several of the online GM parts sites:
1500 part number 23170194
2500 and 3500 part number 23223774
I looked at the cusion part number and they are the same.  Weird
I am betting someone here knows exactly what the difference is.
Thanks
Phil
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
