Hi so on my 09 silverado 1500 4x4 i have noticed a weird plong noise coming from under the hood when i turn the truck off.
just wondering if anyone else out there has had the same issue and/or if anyone can help me resolve this issue is noticed.
  • 7 months later...
Plong ... 🤣
You're going to have to post a vid if you expect any real help on this one.
I like it, slow season, so we are attacking "one and done" posters from 7.5 months ago🤣😂🤣😂
Think I may found what the issue was:
Urban Dictionary : Plong
Placing your ba$$s above the waist of trousers, but beneath your tshirt, and then lifting up your tshirt to reveal your ba##s to random strangers shouting "PLONG".
Maybe he was doing that to close to his truck and they got caught in something🤔😬
  • Haha 1
HA! 🤣
Didn't even notice the date on that one. Wonder why I got an email notification for it? STRANGE ...
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 209 Guests (See full list)
