2020 Dmax Carbon Pro.
I don't recommend the Carbon Pro bed. Had to cut holes to make this work. Otherwise it's nice to have a unique rig that isn't a Toyota or Jeep and still gets 25mpg.
Bumping this thread because I'm in the market as well! How do you like the CVT and RCI rack?
I wouldn't buy from CVT again. It arrived damaged and they told me I could either send it back or just deal with it. I honestly thought they'd give me a hundred bucks off or something and I would have been fine with that. Oh, and the metallic accessories on it are all getting a little rusty already. I'd recommend the roof nest because it's the same design and the same Chinese company makes it anyway, plus their customer service is better from what I hear.
I'd recommend RCI all day though. the rack is sturdy and they make adapters so you can run a tunnel cover. I'll actually be transferring to an RSI smartcap instead, but not for any thing being wrong with the rack. Do you have a carbon pro bed?
Is that a Lomax tonneau cover? Can you open it with the rack in place? All the way?
It is, it can't be opened when the rack is on.its there to keep my air/water/battery system dry.
    Dom Colussi
    Dom Colussi
  • Who's Online   5 Members, 0 Anonymous, 594 Guests (See full list)
