I have a 2014 GMC Sierra 1500 Base regular cab.  Truck had a basic rear view mirror, no temp/ compass.  I bought one on ebay and it came with everything as I was hooking it up I noticed the probe was there from the factory but where would the other be stowed.  I lowered my overhead counsel and did not see a plug, any idea where to look.  Thanks
Welcome to the site.
Which probe did you find, and which one are you looking for (temp or compass)?
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
