accessories HELP!
Hello all, need your help.
Just bought my first truck, 02 Z71 fully loaded and I absolutely love this monster....well, actually I traded into this truck after only a week of having a 2500 HD with the 8.1. Go ahead and laugh because it cost me $1000 to fix my mistake.
Ok so I'm looking at the following this to add and need some advice.
1. nerf bars for the sides of the truck on my extended cab. I was looking at the steps that run about $40 or so but I need to drill and would love to see pics if someone has them.
2. a bull bar instead of the standard brush grill.....most are downright expensive, can you suggest an alternative perhaps?
3. don't have the money for the Line-x bedliner so what are my alternatives? What is the best rail cover and the best plastic map....for now of course.
4. lastly, I want to change over to HID or white lights and am afraid of melting the casings for my fog lamps, high beam and low beam.
Wew, lots of questions but thanks for your help all.
:D:jester:
:D:jester:
I put a GoRhino grilleguard on my truck. I believe it was in the neighborhood of $300. You could go a few ways on the bed protection- either a bed mat or a hard liner from Penda or another depending on what you want to haul. I had a plastic bedliner when I first got the truck as I was short on funds as well. I then replaced it with a Permatech spray-on. As for lighting, if you want the white look, but want to save on cash, consider the Sylvania Silverstar bulbs. I just switched over and find them to give a nice white beam that is slightly brighter than stock. Not a bad mod for a reasonable price. Going true HID's is going to be a chunk of change.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
