I didn't buy one because my issue is always the open air element and heat soak that can happen. That little wall they make still won't stop all the engine bay heat from getting to the filter. At freeway speeds it may not be as noticeable but other times it will be. If you want a cleaner look you could look at the Airaid intake tubes that keep the factory sealed box.
Aside from that, that kit looks fine. A filter cover will help with dust/dirt build up for sure.
Wasn't there dyno sheets posted at one point that showed the air raid tube gave the best results?
Edited by Lsgun1
Can you expand on this a bit? I don’t understand what “it” is when you say it will be noticeable at “other times” other than highway speeds. Do you mean the heat soak? Can you actually feel your heat soak or are you just reading your temp gauges? These open concept CAI’s are VERY common and have been adopted by all of the top-tier companies including airaid and K&N. Common sense would have me agree that more heat is making it to the filter but my competence would have me questioning why these companies would develop and sell a product that was significantly impacted by any of these factors. Just trying to understand whether this is completely your dry opinion or if it’s backed up by some info / experience.
I'm talking about when sitting still or in traffic. The intake air temps will sky rocket in the warmer months because of the open air design. I use my HP Tuners tuning software to find all this out.
I'm looking at it from a driveability and performance aspect. With really high intake temps the computer will reduce ignition timing by a good amount. I see this all the time when people that use their vehicles for performance applications like auto-cross, drag racing etc etc. When speeds are slower and when someone is in the staging lanes the intake temps will get much hotter than ambient temps, so when they go to floor it there is less power because of reduced timing plus hot air makes less power than cooler air.
None of these companies will tell you this stuff and just say it made 8-10 more horsepower over stock on a dyno with a giant fan blowing on the front of the vehicle with the hood open. None of them make a pull on the dyno after it's been idling for 5 minutes with zero airflow across the front. It would take many many seconds for the engine to start pulling in cooler air from outside and bring temps back down closer to ambient. The open air intakes are really just for sound too, not having a seal intake box makes you hear all the noises too.
Edited by CamGTP
[mention]CamGTP [/mention] very much appreciate the extended info. Sorry I sounded a little hot in my first response, I come off a bit blunt sometimes but I am just ignorant in this subject and wanted to understand some more.
    B07
    B07
  • Who's Online   2 Members, 1 Anonymous, 833 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
