Checking to see if anyone has had continuous alignment issues with their 2020 Silverado 1500s? I have a 2020 with just over 5,000 miles on it and have been to the shop 5 different times now for alignment trouble. Each time fixes it briefly but then before too long it is off center again. If I am on fairly flat ground moving, the steering wheel sits cranked to the right slightly and it will hold the lane fairly well if I take my hand off the wheel for a moment. Does not veer. It is pretty rare the wheel centers again until I am actually stopped. Feels like the wheel is constantly turned to the right slightly running in town. Is this a steering assist of some sort Chevy has? I talked to a friend who has a 2020 as well and he is not having this issue. The other issue I am having is that when I am backing out of my driveway and I turn the wheel most of the way to the right and into the street, the truck will make a fairly loud pop in the suspension of the driver side front wheel only. You can feel it a bit in the steering wheel as well.
I lost faith in the first dealer I took it to after the first few times and took it to another Chevy dealer in town this past time for a second opinion. Still having issues after they put it on their rack. Help!!!
I have a 2021 RST.  When I picked it up the steering wheel was off centered to the right. Brought it in and had it aligned. Then it was off centered to the left. Brought it in again. Now it's off to the right again. I give up.
It does drive straight though.
Edited by Diamond817
When turning hard one way or the other and you hear a POP, more than likely a ball-joint issue. Many techs will check alignment and fix what they see at that time. When you have a out of center steering wheel issue the front end alignment needs to me completely redone from the start. Simply getting one side back into alignment does not fix all issues!! The problem with all vehicles shops these days the techs are required to go by the appropriate vehicle service manual which tells them step by step what the troubleshooting/repair procedure is. They are not allowed to deviate from the manual even though at times common sense tells them to do so! This is because GM, Ford, RAM, etc is footing the bill for a warranty repair and will not pay them to do something that is not in the manual. Most dealer mechanics are also paid "By the job". If it takes a mechanic 1 hour to complete what the book says takes an hour, he is paid for 1 hour. If it takes him 2 hours he is still paid for 1 hour. On the other hand if it takes him 30 minutes to complete it, he is still paid for 1 hour. All that being said, "Most" dealer mechanics will rush through jobs to get as many jobs completed in a day which in turn puts more money in his and the dealers pocket. So, what all that means is "Most" dealers could care less if the job gets the problem fixed or not. If it does great, if it doesn't the manufacturer will pay them to work on it again!! However, a "Non-Dealer" shop will do whatever it takes to fix the issue because once they are paid they don't want the vehicle back to be fixed again on their dime!! Sorry for the rant but having repeat issues with vehicles over the years, and knowing a GM Service manager, I know this to be fact!
  • 4 months later...
  • 1 year later...
I am having the "pop" also.  After 3 trips to the dealership and it getting elevated to their senior mechanic, they found that there were damaged alignment pins that were allowing the assembly to shift.  They have ordered a new kit that is supposed to be more robust, so we'll see if that fixes the issue.  Alignment is a known issue on Silverados on the upper control arm also, due to the adjustment slot allowing creep.  There is an aftermarket with holes instead of a slot.  I may have to go that route also.
  • 1 year later...
I had the problem,I have a 2020 Silverado RST I took in for repairs right lower control arm was bad discovered the alignment pins were missing never installed in assembly
    • I work at a Chevrolet dealership & hear it all believe me.  Just reads like there's going to be a fist fight over filters.  Can't get enough, continue!!
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
