Hey everyone, so I have an 05 1500 Chevy Silverado, I have heard that the 706 heads generally go out around 140k miles and I’m sitting at 138k.
wanting to get ahead of the break, I’m looking into replacing my heads. Does anyone have any suggestions as to what heads and or brands of heads to put on? Can I get 706 heads that aren’t castech?
thanks in advance and sorry if this is a dumb question I just started working on this truck the past couple months.
Did you even look to see if you have Castech right now?
Yes there are non castech 706/862 heads, GM had a few different cylinder head suppliers. Your other option is a 799 or 243 cylinder head.
No I have not, I'll have to check. But thank you, I wasn't aware they had multiple suppliers, I thought all the 706 heads were by castech.
This is what I found after removing the valve covers. So the heads are cracked correct? Are there any other issues that could cause this?
If the oil is milky as well and the coolant temp is dropping, then yeah you have an issue.
It's hard to tell if that is a coolant mix or just a real bad oil change maintenance with a bad PCV system on the drivers side head.
Also, if you can't do anything right away.  You can add GM's coolant tablets to the system to help seal it.
GM used these tablets in the Corvettes and Cadillac's that had iron blocks and aluminum heads to keep leaks from forming due to the heat and cooling differences in iron and aluminum.
I used these in my 2002 Silverado when I changed out the coolant.  Never had any issues with it.  I don't know if I had the Castech heads but I just wanted to be proactive.  All my UOA's came back great.
A friend of mine had the Castech heads and had a leak.  I told him to use these until he could afford to do a head swap.  He had good luck with it and never had a leak afterwards and never did change out the heads.  I guess he was lucky.  He just did a coolant flush to clean out the oil in the system and added the tablets.  He also did several short interval oil changes.
Thanks is there anything I need to do with all the goo inside the valve covers other than just clean them out?
Clean them out the best you can and then put them back on.  Then I would flush the coolant and add the tablets.  All of them that come in the pack.  That is what I did.  Then run short interval oil changes.  Get Walmart Supertech oil and filters and run 1,500 mile changes or even less for about four changes.  That is what I would do. Then keep an eye on it to see if it is still leaking.
Is the coolant reservoir still clean and orange?  If it is then the leak isn't that bad  yet.
    250.3k
    chfkief
    chfkief
  • Who's Online   2 Members, 0 Anonymous, 1,536 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
