Hey guys,
I am about to pick up my 21 1500 LTZ Diesel in the next few days.  l was planning on going with the 4" Readylift SST with the stock wheels and 295/65R20.  Does anyone know what is the total height of the truck on this lift installed?  I ask because I park in a parking deck at work and cant fit if over 7'.  I have looked and looked, but can't find an answer
Thanks for any input
Hey, so I have a Trail boss with a 2" SST lift kit (pretty much the same as a stock +4). I have 35X12.5R18 (pretty much the same height as the tires you listed) and my truck measures 80 inches to the fin. Just 4 inches short of 7 feet. Hope that helps.
Thanks for the input!  That is just what I needed- I could not get any input on the actual height of the truck
On 5/4/2021 at 11:18 AM, paxamus said:
Hey guys,
This is my post from Nov 2019 when I did my ReadyLift +2 inch lift kit
Ok guys, I did it.  I installed the lift this weekend and my Trail Boss is noticeably higher up than it was stock.  I am now running 35x12.5R20s on a total 4 inch lift.  My rims are 20x9s with a 0 mm offset, however I added 1.5" spacers to stick the tires out even more.  They sit about 3 inches past the fender line and it really balances out the truck nicely.  Without the spacers there was a very minimal rub only at full lock.  To run the spacers, I trimmed the first wall part of the mudflap (see pictures below) and with the spacers there is only a small touch at full lock now which I have no problem with.  The truck rides fantastic, even better than stock and is super stable around turns.  See below for pictures and before/after measurements.  Best thing is I still fit in my car wash (monthly subscription) which has a 7 ft clearance.  Parking garage wise I believe it will be tight fit, especially with speed bumps for the 7 ft ones but a 7' 6" garage should clear easily.  As always, any questions just ask.
Before:
Front Fender to Floor: 39 7/8
Rear Fender to Floor: 41 1/8
Cab Height: 77
Roof Antenna Height: 2 3/4
Hood Height: 52
Bed Height: 58 1/4
Front Bumper Ground Clearance: 14
Front Suspension Ground Clearance: 11 1/8
Side Ground Clearance: 16 5/8
Rear Bumper Ground Clearance: 20 3/8
Rear Diff Ground Clearance: 9 1/2
Front Distance from Top of Tire to Fender: 7 7/8
Rear Distance from Top of Tire to Fender: 9
After:
Front Fender to Floor: 42 3/8
Rear Fender to Floor: 43 1/8
Cab Height: 80
Hood Height: 54 1/2
Bed Height: 59 5/8
Front Bumper Ground Clearance: 16 1/2
Front Suspension Ground Clearance: 14
Side Ground Clearance: 18 3/4
Rear Bumper Ground Clearance: 21 7/8
Rear Diff Ground Clearance: 10 3/16
Front Distance from Top of Tire to Fender: 8 3/8
    ballencd
    ballencd
  • Who's Online   2 Members, 0 Anonymous, 454 Guests (See full list)
