Has anyone noticed the 8 speed doesn’t shift down to first gear at a rolling stop. Even on a hill I have to manually shift it to first unless I stop long enough for the start/stop feature to kill the engine.
This is certainly not what we like to hear, Hbsurvey23.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your truck. To do so, please send an email to [email protected] with ATTN: Hbsurvey23/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
  • 1 year later...
So here is my experience I also had the 1-2 shift problem mine is a 2020  been to dealer 5 time 36k miles  2 fluid flushes  then they changed to torque converter  and Valvebody  continued to do was  even told you have to break the fluid in bs I work on cars I know better
even had the manager go on drive and showed him what it does  said yep that’s not right  then called at end of day to come get there is nothing they can do  2 months later it had a catastrophic failure welded the clutch plates together   So now the truck has been at the dealer for 3 months waiting on a transmission they are on national back order tried to get gm to do a buy back they refused  never in my life  have I experienced this kind of service. Will be sold if I ever get it back and after owning 6 Silverados it will be my last   Gm you suck
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
