Think I know the answer but is anyone got this in the last couple weeks.  We put money down on a Sierra 2500 in March and they pushed this discount to me, just have to wait until the truck arrives and it will apply they told me.  Well it looks like now they might have done away with it?  Truck is supposed to be here in 2 weeks and it seems like we lost out on a $2000 price break.  Any get the 1st responder discount recently?
Yes, I just used it 2 weeks ago when I bought my 21 Silverado 2500 High Country but now it is only $500.
As the previous poster suggested, the discount is now $500. While I understand that you run this risk when ordering the truck and rebates change, generally speaking these discounts have been more predictable. With that said, I would try to leverage your previous discussions with the dealer and try to negotiate a better dealer discount. When I ordered in February, the dealer beat supplier pricing so it is possible, whether they will do it in this market it is hard to say.
Finalized papers yesterday.  Seems there was a date, May 5 or 6th, where the incentive changed.  My dealer honored the full discount however since I had registered prior to that date, so kuddos to them and lucky for me.  Ultimately we got $3100 off MSRP with FR discount and a couple of other small ones.  Feel fortunate since the other dealers are marking them up 5K and 10K above MSP, yikes.  Now just waiting for the truck to actually show up!
    Fishboat
    Fishboat
  • Who's Online   5 Members, 0 Anonymous, 550 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
