So like an idiot I thought I'd change out my red GMC emblems for black, I did order GM parts, black emblems from the Carbon Pro.  I was able to get the old emblems off okay, but the new ones all the tabs will not snap in tight.   Here I thought getting the old ones out would be the problem, and that was easy!
It looks like the tabs in the grill that capture the hook on the emblem tab are just a bit too long for the new emblems.  From what I can see the emblem tab is not going in far enough to get "captured" fully at all the tabs.
Anyone had this problem, and ideas?   Plenty of pressure has already been applied and then some :)
Edited by todd308
I replaced a set on my 2019 Denali with the chrome and black ones and that went perfect. I traded my 2019 for a 2021 AT4 2 weeks ago and just replaced the front emblems again but this time with an all black set where the chrome is painted gloss black. They will not lock in all the way for exactly the same reason that you described above. What I noticed is that these all black ones have those tabs also painted and that probably added just enough extra size to those clips. I ended up focusing more on locking the top ones in and on the bottom you can reach your hand in underneath and behind the mounting area and wrap your fingers behind where the clips lock in. I was able to get a few of them locked in this way as you can touch the clips. On top however its impossible for me to wrap my fingers behind to get to those clips. Messing with it this way for a while finally got them all locked in.
Yeah I bet that's the issue, sounds like we have the exact same emblems, all black, gloss on the outside and flat on the inside.  In the end like you mentioned for most clips I was able to get behind the grill, flex the hook part of the emblem clip away from the tab that captures the hook, for all but 2 this gave enough extra room to let the grill tab engage the emblem hook.  There were two that were actually just a tiny bit loose (top of the "C") perhaps we damaged/stretched the grill clips in removal, but they ended up snug once the bottom ones were hooked in.
I will say after doing it, I'll never do it again. Installing the upfitter aux switches was less hassle, and that's saying something!
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
