Fan continues to blow air thru vents
The Fan continues to blow air thru the vents while the fan is turned off.
It is hot or cold depending on the temp dial setting.
Is this normal?
Thanks!!
Does anyone know what is the reason for this? When you turn off the air in my 94 it turns the foot fan on.
I always knew there was a continuous airflow, thought it was to prevent asphixiation (sp?). Guess that could be true weather its exhaust fumes or just using up all yer air. I know that on jeeps (cj's, wranglers, etc.) there is positive air pressure at the cowl forcing air into the system. Not sure if this condition still exists with modern aerodynamics.
On my 1999 Chevy Blazer, if you hit the recirculate button it stops air from coming in with the fan off. Don't know if yours has that or not.
