On a 19 LT with a 5.3, 8 sp. with the advanced trailering package does the package do anything for sway control?
Edited by flat350
Silverados have built in trailer sway control.  If you have a sway issue, you most likely have too little truck and too much trailer.  Other issues could be too little weight on the tongue or cheap trailer tires with too much sidewall flex.  But the most common issue is too little truck pulling too much trailer.
You need 10-15% tongue weight. What do you have?
I always take my trailers to a three axle scale at a truck stop near my house and get my trailers dialed in. It's worth the $12 to get it right. Makes my towing so much nicer.
I don't have the trailer yet and I don't foresee a problem with it , only going to be 21' and 4200 lb. dry (travel trailer). Already have a weight dist. hitch and was just trying to figure out what all of the features with the tow package were, literature that you find doesn't seem to be real clear.
If your truck is equipped with StabiliTrak then it has the integrated trailer sway control (TSC) feature.  If you still have the window sticker, it should be listed on the left-hand side under the "Performance & Mechanical" section, separate and distinct from the "Advanced Trailering System" listing on the far right of the sticker, or at least that's how it's listed on my 2020 LT's window sticker.  The towing TSC discussion in my truck's manual (page 304) mentions that if your trailer has a built electronic sway control there could be a conflict with the truck's TSC feature.  Turning off StabiliTrak, which disables TSC as well, has it's own potential issues as well (pages 231-232).  Same potential issue if your WD hitch has built-in sway control, such as an Andersen hitch, which if memory serves me right states on their website that you should turn off/disable a tow vehicle's sway control so it doesn't compete with the hitch's sway control feature built-in with their hitch, but as previously mentioned, the owner's manual offers some cautions if you decide to turn off the truck's StabiliTrak/TSC feature.
Edited by Anacortes Army Guy
Something that size shouldn't give you any sway issues, as long as you have enough weight on the tongue, which shouldn't be an issue once you have propane and a battery on board.  My trailer is a little heavier and I have no sway issues.  In fact, I don't even use the sway bar that came with it, because the trailer is so rock steady.  The only thing I did was replace the cheap China bomb tires on the trailer with Goodyear Endurance tires.  I would recommend you do the same, as having a blowout on a freeway or in the middle of nowhere is no fun.  I found that out the hard way, as have many others.
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 1,159 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
