Getting a "Program Cluster" message everytime I start my 2020 AT4 3500. Just started after 14k miles. Everything seems to be working okay. Is there a way to make this message stop without making a trip to the dealer?
Edited by KKDuramax
Fixed error message from reprogram to program
  • KKDuramax changed the title to Program Cluster message
  • 2 years later...
