Good afternoon. I hope I'm in the right place since I'm new to the forum. If so I have a question about my truck navigation system. I purchased a 2014 Silverado and I notice my navigation does not work. the only thing I see when I click on it is the compass. could anyone provide any info as to what I need to do in order to get my navigation to work?
I believe you only have onstar navigation then. You’ll have to check your codes in the glove box and see what model radio you have. A little search here will tell you what model code has navigation. Sorry I just can’t recall
It'll have be an IO6 code to have factory nav.
I replied in your other thread you started in the Acadia section so I will add it here too:
You more than likely have the IO5 radio which does not have the factory installed navigation.  The "NAV" icon/compass is for Onstar Turn-By-Turn navigation.  If you have a subscription to Onstar that supports turn by turn, you can have them send directions to the truck and the NAV icon will allow displaying of text turn by turn.
In your glovebox there's a white label with a bunch of 3 digit codes printed on it, as well as your VIN.  That label is the SPID label or Service Parts Identification label.  The 3 digit codes called RPO codes (Regular Production Option) tell you the options that are equipped in your truck such as engine, gearing, radio, transmission, etc.
On that label head to the codes that start with "I".  If you see "IO5" you have the non-nav radio which is turn by turn capable.  If you have the "IO6" radio, you have factory navigation.
There are aftermarket upgrade paths to make an IO5 radio have the factory nav from the IO6 radio.  Factory navigation for Chevrolet and GMC vehicles now available! (rostra.com)
    ncleg
    ncleg
  • Who's Online   6 Members, 1 Anonymous, 831 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
    • That’s what I’m wondering is if the stock backspacing of the factory wheels will clear new upper control arms and such
