Open Club  ·  281 members
diesel 3.0
I just completed a draining of the fuel filter to clean out some water in the fuel. It was scarey but really easy in the end. You need a #40 torx driver to open the drain on the cartrifgmmdge housing. It is located in the bottom of the housing. The owners manual supplemental instructions. Once you have done it you will realize it is really easy to do. Also when you change the fuel filter you will need a 6 point 36mm socket to remove and re install the filter cartridge.
