2017 Silverado - ABS and Traction Control Lights, Right Rear Turn failure warning, random battery draw
Hey Guys-
  I am struggling with multiple issues on my 2017 Silverado. The symptoms started with a warning for Right Rear Turn signal failure, although it lights up and works fine. Then the ABS, Traction control and Trailer brake lights and warnings came on. They randomly come and go when I start the truck. Most recently, something is staying on and draining the battery. The Battery draw will happen randomly as well.
   I have read thru previous similar issues, and most related to ground issues. I have checked and cleaned the grounds G101,G102,G121,G141
  I have tried to locate grounds G210 and G218 and they do not appear to be located under the dash panel on this year like others have found on the 2014 models
   I have 2 codes: CO110 and CO800
   Has anyone experienced similar issues, or do you have any guidance on where to go on this issue?
    All of the issues will come and go, but are becoming to be more regular.
  • 2 years later...
I saw that you said you read through similar issues. Just putting this link here just in case you didn’t see this and hopefully it will help.
https://static.nhtsa.gov/odi/tsbs/2017/MC-10113871-9999.pdf
Right now I’m researching an issue where I’m getting u0073 codes inside my EBC and SAS modules. Found what looked like a fuse that got really hot but rings out (ABS Valve? Fuse 25 25A). Now need to look at grounds.
Need to find something that shows all ground locations as well.
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
