2011 silverado 1500 Short story  going down the highway heard a clunk there goes my tire with the bearing and caliper on it cv axle broke with it
I replaced cv axles struts bearings calipers rotors and pads  both sides on the front along with new tires
When I start the truck i have no lights on the dash  soon as I move the triangle  traction light comes on  and service stabilitrack  it seems fine going slow but when I take it  down the road and slow down from 60 it shakes really bad  pretty sure I have it bleed good it's got a good firm pedal  any ideas what would cause the shaking and the light to come on
might be your U-joints are bad to cause the shaking.  Be sure you didnt damage any wires when your suspension dropped out.
What bearings did you use? I've seen the Autozone(cheapies) throw that code right away due to faulty abs sensors in the hub.
They were trq bearings not expensive but not the cheapest I could find either
2 hours ago, It's Tim said:
Was it possible to align the truck to specs?
I'm gonna get an alignment done Friday see if that takes care of it
    250.6k
    overspeed
    overspeed
  • Who's Online   2 Members, 0 Anonymous, 273 Guests (See full list)
