So my dealer installed GMC puddle lamps didn’t ship with our ‘21 Denali.
Called me this week to tell me they finally came in.  My dealer (who is great) popped them in and off I went.
So tonight, this is what I see.
Well, look at it this way, you didn t have to pay $100k for the cadillac.
