Hey all. New to the site but could use some help. About 3 months ago my truck randomly started to misfire. Hooked up code reader and got P0300. If I drive it for a bit it will also show cyl 4. So far I’ve changed plugs and wires. Unhooked coil packs individually which did narrow it down to cyl 4. Changed that pack with no luck. I put seafoam in and took it for a good rip. No change. Just recently changed all 8 injectors. It now idles more rough and has less power. While shifting from 1-2 it will slam into gear, and now there’s some noise under the truck I haven’t  found yet. I checked compression on cyl 4 and it was good. Checked all injector wires and they’re good. Anyone have any suggestion???
Edited by BigMac93
Spelling mistake
Is the misfire still on cylinder 4?
That is a AFM/DoD cylinder on the GEN 4 engines in the 2007.5+ trucks.
Yes. Still on 4. But I did take the valve cover off and hand cranked the engine and lifters were working fine
    • 37's would probably fit with a 3" lift. GM only has two gear ratios for these trucks 3.73 for gas and 3.42 for diesel. And they can't be programmed for anything else at the moment. The rough country module just corrects the speedometer and odometer to adjust for tire size it's not a programming device.   You haven't said if your truck is gas or diesel, but for a gas truck the 10L1000 with 3.73 gears has a lower final drive ratio than the 6L90 it replaced would if it were swapped to 4.10s. GM used the same 3.73 gearing in 6 speed gas trucks. I don't think you'll have any issue running 37's with the 10 speed other than the reduction in mpg and towing/weight capacity which is as much of a function of the lift as the tire size.
    • Actually, it probably was the brakes.  It's weird the way the messages came across, but I took it to the dealer thinking that something was wrong with the sensor and in fact, the rear brakes were shot.  What I don't understand is why the messages never said, your brake pads are low.  First I got the message I posted above, taking about new pads being detected.  Then I got a message saying that the system needed repaired.  It never said, change your brake pads.
    • Did the KYBs keep it the same height in the front? I was concerned that pre-assembled assembly would raise it up an inch to standard non-z60 height.. I guess which it would make the rake 1 inch instead of 2 inches.
    • Thank you for keeping the train on the tracks and for a thoughtful engagement. I enjoyed the reflection on a previous stance to refine and improve your position. I like that inquisitive flexibility about you Atlas.    No the process isn't sterile. Hundreds, perhaps thousands of miles of piping, vessels, pumps. Chevron, the people I worked for, were keenly aware that there is a market for what is known as their "ISOCLEAN" line of lubricants. These are lubricants that are the same as those sold bulk that are further processed by filtration to a level your particular application demands. They will filter and package and provide lab documentation as required. Do not kid yourself. Every gallon of oil that goes into a Chevron Turbine, reciprocating compressor, generator is prefiltered and tested before being charged. Lest wise it was when I was there in the plants I worked in.    There are requirements set by manufactures for the cleanliness of the oils used in their equipment. OTR such as CUMMINS has standards shared with customers on this. Commercial interest selling to Ma and Pa do, but don't share that information. Not even upon request but internally, they do exist.    The GM study sited, (Graph from Machinery Lubrication in previous post) only shows "relative" importance.  I find that fascinating. By constructing the graph like this they admit there are dozens of factors in engine life and via scientific method determined the effect of 'relative cleanliness' on engine life not in miles but in 'FACTORS'. This allows a certain amount of reverse engineering does it not?   They even provided some touchstones. Beta 75 as a reference point. Wonderful stuff!!   Smaller blenders CAN and some DO take the time and effort to do better than a refinery or large bulk blender, like Warren Oil, in improving the "in the can" cleanliness. No I don't have a list but testing could generate that information.    Again, but one of several levers we can pull to improve engine life. The simplest is keeping a clean work station while doing your own oil changes.
