New issue….
The other day I filled up with gas.  The pump shut off at full automatically.  Got in my truck, started it, and the gas gauge was only at 3/4 and the miles remaining to empty were at 359, lower than usual for a full tank.  Hmmm.
By the time I drove 20 miles home, the gas gauge had gone up to full and I had 393 miles left till empty.  Normal.
Got in the next morning to go to work and I had 299 miles to go and less than 3/4 of a tank.  Nobody stole my truck and drove it during the night.
Went to work again.  Miles left got al the way up to 384.   Got in after work, 276 miles to empty.  Drove a bit and was idling at a red light.   Noticed my miles left to empty were actively flipping, going way down then way up. Happened every time I was stopped.
I get that the miles left feature depends on driving history.  It also moves the gauge dial.
I made a service appointment for a week from tomorrow.  I have pics and video. This is a new issue, I’ve had my truck for 2 years and this has never happened.
Anyone else?  Any idea what’s wrong?
2019 TB, 29200 miles.
Sounds like a fuel pump issue via the float.  Just a random guess because I'm not very good at diagnosing over the phone.
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
