About a week a go I took my 2014 Silverado 5.3 out for a drive and out of nowhere the gauges started going crazy. The brake, abs, and check engine light came on. There was also a message about servicing the power steering. Turned it off and let it sat for a while and all the lights were gone other than the check engine light. I drove it and the steering wheel was hard like I had no power steering. About 10 minutes into driving everything went away and truck drove like normal and gauges went back to normal. When I got home I put on the obd and got nothing but communication codes but they cleared after reseting. I have since cleaned all the grounds. There was two on the frame one by the driver side and one by the passenger behind the front wheel well. There was two on the dash one by the driver side tweeter and another by the passenger. Also cleaned one out that was in the back above the spare tire. Same issue after cleaning the grounds so I replaced the battery ground cable with another new oem from dealer. Still same issue. I turned on the truck in the drive way and about 15 mins in it started going crazy again with service brake and service power steering and check engine light lit up. Battery seems old but cranks up every time even after weeks of not driving it. I have ordered a new distribution box to see if that fixes the issue. Need some help fixing this issue. I figured if it was a bad module it just would not work from crank and not wait 15 minutes after crank to tell me its bad. I checked harness under frame and it looks good.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
