Open Club  ·  281 members
diesel 3.0
I've got about 2,000 km on mine and oil life monitor shows 85%. The owners manual doesn't mention anything special about the first oil change other than the regular 12,000 km interval.  What's the general consensus for a reasonable amount of kilometers till first change?
  • Sad 1
  • 4 weeks later...
  • 1 month later...
I did the first one myself at 5,500 miles a couple weeks ago. I did pickup 1mpg it seems using DexosD 0w20 and a upf66r filter
It depends on how soon your dealer will let you come in to have it changed to use the free ones.  If it was mine I would get it done at 1,600 km.  Then go by the OLM from there.  I like to get the factory fluid out and any machining material that might be in there out.
Do you have to?  No but I feel better.
  • 5 months later...
Resurrecting the thread a bit. My question is if the first oil that is installed by the factory is not regular off-the-shelf oil. I know first filter on my two 5.3d were different from store or dealer sold filters. I am thinking if the factory fill contains anything that helps with the break-in. Has anyone done any oil analysis on the 3.0 factory fills to see if they use regular oil or not? If break-in oil is in, I would guess it is beneficial to let it run longer.
  • 3 weeks later...
I always change out the factory oil at around 1,000 or less. Just want to get any of the particles from the manufacturing process out of there. On my new 2022 Sierra which I am taking delivery of this week with the 3.0 I will follow the same pattern I have on my other vehicles. I never pay attention to what the oil life monitor says and I will change every 5K using either the AC Delco Dexos or the Mobil 1 Dexos compatible oil with either the AC or Mobil 1 filter. Looks like oil changes on this engine a snap compared to my 2017 Ram which was always a guaranteed mess with the way they mounted the filter on the Hemi. To me clean high quality oil is cheap insurance.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,047 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
