Hey folks:
Just traded in my '11 LTZ Z71 and am now the happy owner of a new 2021 AT4 here - pic below!
I can't seem to figure out how to get my mirrors to tilt down when I throw the truck in reverse... this was probably one of my favourite features on my old truck.  I searched this forum and others and can't seem to find ANYTHING on this - did GM delete this functionality or am I just missing a setting somewhere?
Thanks in advance!
2021 1500 Sierra Owners Manual:
Reverse Tilt Mirrors
If equipped with reverse tilt mirrors and memory seats, the passenger and/or driver
mirror tilts to a preselected position when the vehicle is in R (Reverse). This allows the
curb to be seen when parallel parking.
The mirror(s) may move from their tilted position when:
. The vehicle is shifted out of R (Reverse), or remains in R (Reverse) for about 30 seconds.
. The vehicle is turned off.
. The vehicle is driven in R (Reverse) above a set speed.
To turn this feature on or off, see Vehicle
Personalization pg 130.
Reverse Tilt Mirror
When on, the driver, passenger, or both driver and passenger outside mirrors will tilt
 downward when the vehicle is shifted into R (Reverse) to improve visibility of the
ground near the rear wheels. They may move from their tilted position when the vehicle is shifted out of R (Reverse) or
turned off.
See Reverse Tilt Mirrors pg 38.
Touch Off, On - Driver and Passenger, On -
Driver, or On - Passenger.
Edited by redwngr
You have to enable it in the settings menu first. Very useful feature. I just haven’t been able to reposition and save the new position like on my 2015 Denali.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
