So, not sure if there is a for sale/trade section but I have some gear for sale.
1: Audio Control D-6.1200 Amplifier with ARC3 controller
2: 300AMP Stinger circuit Breaker, Stinger Distribution Block, Stinger power/ground wire
3: LLJ Customs loopback harness with 20' leads (Black and Grey connectors). This length allowed me to go down the driver side so the wire did not lay next to the power wire.
This is a complete setup to install a dual amp setup in a 2019 and up Silverado/Sierra with the black and grey connectors. I sold the subs and mono block separately.. Price is $800 and I am in the DFW area. I will ship at buyers expense. Would be better to email me as I don't check this site constantly. My email address is [email protected]
IMG_4464.thumb.jpeg.bf2654e493066ef820cf75088c718369.jpegIMG_4463.thumb.jpeg.2092844bdd33271e3c9be884d0113782.jpegIMG_4465.thumb.jpeg.ef89ae6bf02e76e09b3bd408637ef40b.jpeg
  • 8 months later...
I know you were trying to sell this, but I'm curious what you thought of the setup in the truck and what speaker setup you were running with it.
  • 4 weeks later...
The setup is awesome. When I had my 19 Silverado I was running all sundown speakers. 2.75 in the dash, 6.5 components in the front doors and 6.5 coals in the rear doors. Used the D-6.1200 to power those. I had a pair of 10" sundown Audio E series under the rear seat powered by a 1500W mono block also from Sundown. It was pretty awesome. Sold the 19 Silverado and picked up a 21 AT4 3.0 Diesel. Changed the setup a bit. 2.75 sundown's in the dash, Sundown 6x9 in the front doors and 6.5 coals in the rear. Running the JL Audio Stealth box under the seat powered with the Audio Control LC1.800 amp. I miss the sundown subs if im being honest. Wish I never sold them.
