I added a pair of subs about a year ago and recently decided that the rest of the system needed an upgrade.  It started as the bose system in my trail boss. I removed every factory speaker except the center console sub.  The factory sub has been disconnected but is too big of a hassle right now to remove or replace and wire in with my other 2 subs.
Because this information is not easily able to be found online I want to share that the dash speakers and the rear door speakers are 4 ohm speakers.  The front door speakers are 2 ohm.  The dash speakers are the only ones that say "BOSE" on them.  Not sure that means anything its just an observation.  I did not measure the subs resistance level as I did not remove it. I could have tested the wires that ran to it but forgot about it before it was too late.
The parts list is...
JL audio vxi 1000/1
JL audio vxi 800/8
JL audio fix 82
JL audio vxi hub
JL audio vxi btc
JL audio amp wiring kit
JL audio 10tw3 subs
Hertz 6.5" in all 4 doors
Hertz 3" in dash
Hertz tweeters on pillars
As most are aware there is very little room back there. I had to get creative with how I was going to mount 2 amps and a couple of other accessories.  Under the rear seat is completely taken up with the sub box.  After I removed the back seat and got to looking at it I decided that I needed to move some stuff around.  Since I was going to install sound skins on the back wall and all door panels anyways I removed all the factory components from the back wall. I then installed the sound skins and took some measurements.  I designed up some new brackets and cut them out of carbon fiber plate as I needed something as thin and rigid as possible. I wound up moving the power inverter over to the drivers side as there was a big empty space there and utilized the factory "amp rack" to mount the JL audio fix 82, vxi hub, and vxi-btc bluetooth adapter. Closer to the passenger side I found a good space to mount the fuse block.
After that was squared away. I replaced all the door speakers and added sound skins to them as well.
I found these aluminum tweeter pods on ebay and they didn't disappoint.
I mounted the amps in the back seat storage pockets. I'm not going into a whole lot of detail about it because you just have to wing it on this one. Take some careful measurements and trim some of the plastic in the bottom of that storage pocket. Its not a fun job but not difficult either.
Edited by DK91105
  • Like 3
I forgot to add that while I was in there I added the lighted sill plates. There is some confusion if these will work for a 19' model as they are stated to be for 20+. I can confirm that they install and work as intended just as the instructions say. After installing the plates on the trim pieces it took maybe 30 min to wire them in and put it back together.
Edited by DK91105
13 minutes ago, It's Tim said:
I forsee guaranteed electrical gremlins in your rides future.
Thats cute. Everything is tight and right bro.  You want to hate for whatever reason but if that's all you got go be pathetic somewhere else.
  • Like 3
1 minute ago, eppieguy said:
Nice Work, I wish I had that talent.
Thank you!   It didn't all come to me overnight I promise you that. I'm so picky about how things are it takes me forever to get a project done. That's about 3 weeks of off and on work for the install.
Seems to be well worth it to me!
Ok, the key question - how does it sound? :)  Do you feel it was worth that amount of work? My ears are not what they once were, so a lot of nuance in a high end system is lost on me.....
Did moving the dash tweeters up and pointing them out make a big difference? (I suppose you wouldn't know for sure without mounting them in the original position first...)
Edited by Chris Callanan
This is the type of thing that is all personal opinion but I think it sounds fantastic so far. You don't realize a bunch of the notes that you cant hear without tweeters.  I put a replacement 3" speaker in the spot where the factory 2.75" speakers were so the tweeters had to go somewhere else.
These are the new dash speakers. I had to cut some adapter rings for these as well.
Edited by DK91105
14 minutes ago, Chris Callanan said:
So you went from basically 6+sub to 8+sub system...  nice.  Excellent work.
Correct, and thank you.
  • 2 months later...
Great install
Any pics of the midrange in the dash?
Did you have to trim the opening any?
thx
On 12/5/2021 at 3:54 PM, BT3 said:
Great install
thx
Sorry for the late reply, yes. I had to trim the opening. I used a dremel with a right angle attachment / sanding drum. It was easy to do but was slow as it was trial and error. I didn't want to remove too much so I did a little, stopped and checked, repeat....  Its not pretty but you cant see any of it once the cover is on.
Edited by DK91105
  • 3 years later...
    DaleB
    DaleB
  • Who's Online   4 Members, 0 Anonymous, 1,414 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
