Last weekend I washed my truck and afterwards the upper tailgate was unlatching itself on its own. After Tuesday didn’t have any issues with it doing it again. Washed my truck today and I notice when I open any of the doors the upper portion is unlatching itself again. Anyone else have or had this issue. Truck is a 21 Denali 2500. Thanks.
I've had them open when spraying the switches with a high pressure hose.
I've not had them open on their own afterwards.
Same with the rear gate on an Acadia
Edited by redwngr
Have the same issue, I unplugged the switch and it stopped doing it.  A lot of people seem to be having this issue, looks like a batch of bad switches.
Took it to the dealer and they ordered me a new switch and of course while it was there it decided it wouldn’t open up on its own. However before leaving we couldn’t get the top to open at all and still not working. Bad switch. Now just waiting on the parts to arrive.
I've recently started having the same issue. Mine started with the infotainment system update. The next day the inner tailgate started opening anytime I open a door. I've been talking with dealer and no fix yet on my end. Truck is a 21 Denali 3500.
The bottom switch quit working about a week after. . They replaced upper tailgate switch and bottom switch getting replaced this week. So in case you run into the same issues there is 2 switches and not one like I had thought.
    HWN808
    HWN808
  • Who's Online   4 Members, 0 Anonymous, 1,004 Guests (See full list)
    • https://www.gm-trucks.com/why-gm-chose-0w-30-gen-6-v8-oil/   The swing back to reality continues…
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
