Anyone know or have any insight on what chassis changes were made to allow for an increase of nearly 4000lbs for the ‘22 Duramax?
Is it a change to the boxed frame?
I understand it's springs, cooling, and a 3.73 rear end.
The frame is already boxed on T1.  1/2 ton frames have been boxed since 2007 with the GMT-900.
All they've done is add what they do with the gas powered NHT.  Higher capacity cooling, 3.73 gears, 9.76" axle, different springs and shocks.  The 10 speed does get a shift calibration tweak to it as well with the diesel.
Sorry, I wasn’t clear about the boxed frame, knew it’s been there for awhile.
GM mentioned they made changes to the chassis to allow them to fit the Max Trailering package.  Apparently they weren’t able to do that before until the recent change.  Their press release mentions this and I think some YT video as well.  I’ll have to find it again.
647465884_ScreenShot2021-09-16at3_18_29PM.thumb.png.0b4a3ae5fbdb71eceda4a2bf280c032f.png
Does chassis mean frame here?  If so, what were the changes to the frame?
Edit:  So here is another mention from Pickup Truck Plus SUV Talk, that GM had an issue with the chassis before that didn't allow for Max towing.
Edited by SilveradoRST
No frame changes.  What they probably have done is just repackage the cooling area with the updated front end so it can accommodate the added cooling with the I6 configuration.
That was the issue with the 2020-2021 trucks was cooling flow.  GM knew that the diesel could tow more than 9300lbs when it launched, but they couldn't get more airflow in with that engine.  DPF is under the hood on the 3.0 trucks, not under the truck like the HDs, so engine compartment airflow is crucial.
EDIT:  Here is the article with the engineer talking about heat reduction back in 2019 on the 3.0:
GM Looking To Upgrade Tow Ratings For Half-Ton Duramax Pickup Trucks (musclecarsandtrucks.com)
They must have figured something out but just waited until the refresh to drop the upgrades.
Edited by newdude
  • Thanks 1
Damn Newdude always dropping knowledge on us. Thanks for educating  us Newdude
Just retain useless info sometimes LOL.  I put the link above from the engineer back in 2019 talking about the heat issue they had to address.
Of all the research I did before purchasing my Duramax Sierra Elevation X31 in June 2021, I never ran across that linked article.  It did a great job of pulling everything together despite it being from a few years ago.  Thanks for sharing.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 423 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
