Hi I have a 2018 Silverado with a 6.2 l and I have a code P0131 which from what I can gather is a 02 sensor 1 bank 1 and I think that would be be the upstream sensor but I was wondering on what side on the engine any help would be greatly appreciated.
    smandy
    smandy
  • Who's Online   4 Members, 0 Anonymous, 522 Guests (See full list)
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
