3 hours ago, DDgoose08 said:
Hello all,
                  I'm looking for help in locating the rocker switch or button for my 2019 Silverado 1500 LTZ as shown in the picture.2019 Overhead Console Switch.pdf
What specifically are you looking for? Replacement? Exact switch?
I took down the console and it’s not a switch. It’s actually looks like a circuit board and the attached pictures are of the rocker lever that broke off. So I’m looking for a replacement rocker lever.
See the source image
That would be a great place to start.
My guess is going to be that the individual switch will not be sold separately, meaning you have to but the whole unit.
How many plugs are there for that piece (Part switch is from)?
There’s only one, and it’s not a switch. It pivots on a pin and rocks back and forth for open and close as pictured below. There’s a circuit board that has a micro switch built in it and has (2) high points that trigger either open or closed. Same concept they use on a TV remote.
Edited by DDgoose08
    Bert 22
    Bert 22
  • Who's Online   1 Member, 0 Anonymous, 793 Guests (See full list)
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
