I have scoured the internet and even this forum and have only found one post that really addresses this issue on the 2019-2021 Silverado/Sierra 1500’s. One person here said they found the fuse that controlled it, but didn’t elaborate as to which fuse so I went and checked every fuse I saw under the hood and was unable to figure out how to fix this issue.
Fuse #63 says trailer power, but has nothing to do with the 12V Power Pin on the 7 Pin connection.
If anyone can shed light on the solution to my problem, it would be greatly appreciated.
I pull a travel trailer so this piqued my interest. I have 2020 1500 LT with Max Trailering package. I put a 12v meter on my  truck's 7 pin connector at ground & 12v+ charging. I, too, did not get any voltage with truck off, accessory mode, or running. However, I'm pretty confident my trailer is getting at least 12v from truck when traveling. I'm guessing there must be a condition that has to be met before truck sends 12v thru 7 pin connector. Such as, trailer plug connected and 12v from trailer is detected...just a wild guess. My 30 amp fuse at #63 (Trailer battery) looks good. I'll check more when trailer is connected again.
Thanks, I really need to figure this out.
  • 6 months later...
Kind of an old post, but on one of my trailers the emergency breakaway system has LED lights showing the battery status, and when the truck is on, it does show the status as charging the breakaway system battery.
I guess you could put a meter on the trailer battery with the truck off, and see if the reading increases when you start the truck. I don't know if it is a regulated 12v to the back, or a higher (alternator) voltage for charging.
Edited by Coastie
I hope you solved your issue by now. My fuse #63 in engine compartment for trailer battery looked fine, but still no 12v at 7-pin connector. I pulled fuse out, popped off it's cover and it is blown. Simply replacing the 30 amp fuse restored 12v at trailer connector, even when truck is off.
    • I agree with Tim.  As tech heavy as engines are these days, no way I’d be an early buyer of the new 6.6.  Of course, I bought my ‘26 Denali w/the 6.2 after dumping my Tundra with it’s defective 3.5 liter imploding engine disaster, so I’m a little gun-shy.  That said, my 6.2 has been rock solid.  I don’t drive it like I do my BMW Z4 M40i, but I don’t baby it either.  I got a V8 for a reason.  But I’m averaging 18 around town and 22 highway.  I have seen 24 highway as well when I wasn’t loaded up heavy.  Considering my Tundra with the twin turbo V6 only got 14.5 in town and 17 on the road, I’ll take the 6.2 all day, every day.  If I were you, I’d grab a ‘26 while you can.  Inventories are probably gonna start dropping and I’ll bet the deals will start looking sweeter as well.
    • I am curious if anyone has figured out a way to add an hard button AUX or 360 Camera switch to the center row of switches. I have a 2021 AT4, and want to split the hill decent button and add a 360 camera button so that you don't have to go into the center display and locate the camera functionality, etc...   My father's 2024 Yukon XL AT4 and it has a hard button, see below. I found this thread on the Yukons, but it seems like there may not be a part number for the 2021 sierras. https://www.gm-trucks.com/forums/topic/255339-adding-hard-button-for-camera-on-2021/ Anyone else figured this out. Seems like it would need to be a custom switch!   I am getting ready to install the auto stop/start eliminator, so would be nice to knock them out at once.     Upvote1Downvote0Go to comments
    • Looks like the entire state is burning. 😬
    • Through the years it hasn't been my typical method as I tried to drop oil on an engine that was hot from having been worked, however that was not always practical and had to fire up a unit and let it warm up reasonably well and drop the oil when I had the time to do it but am referring to not only vehicles but a variety of farm equipment and highway tractors etc. However on a vehicle where one is crawling under it and the exhaust is nearby to ones body and if wanting to pull the plug without danger of being hit with boiling hot oil or attempting to remove a HOT oil filter, its sure safer and easier to not have everything smoking hot and can remove the filter right away when under the vehicle and let it all drain. Of course its not the end of the world if a bit of oil stays in the engine that might have eventually found its way out, I like to get out as much as possible but any oil changes that take place in shops would rarely be sitting around for very long at all before the plug is thrown back in and filter slapped on and oil poured in and sent out the door quick like. There would be very little time spent ( assuming they even did it ) in starting the engine with oil to fill the filter, then waiting to verify the level on the stick. A good reason to check ones oil level shortly after a shop changed the oil on a vehicle just to make sure its correct and to look under for any oil around the drain plug or filter.
    • Cool to see another Vermonter!
