I have scoured the internet and even this forum and have only found one post that really addresses this issue on the 2019-2021 Silverado/Sierra 1500’s. One person here said they found the fuse that controlled it, but didn’t elaborate as to which fuse so I went and checked every fuse I saw under the hood and was unable to figure out how to fix this issue.
Fuse #63 says trailer power, but has nothing to do with the 12V Power Pin on the 7 Pin connection.
If anyone can shed light on the solution to my problem, it would be greatly appreciated.
I pull a travel trailer so this piqued my interest. I have 2020 1500 LT with Max Trailering package. I put a 12v meter on my  truck's 7 pin connector at ground & 12v+ charging. I, too, did not get any voltage with truck off, accessory mode, or running. However, I'm pretty confident my trailer is getting at least 12v from truck when traveling. I'm guessing there must be a condition that has to be met before truck sends 12v thru 7 pin connector. Such as, trailer plug connected and 12v from trailer is detected...just a wild guess. My 30 amp fuse at #63 (Trailer battery) looks good. I'll check more when trailer is connected again.
Thanks, I really need to figure this out.
  • 6 months later...
Kind of an old post, but on one of my trailers the emergency breakaway system has LED lights showing the battery status, and when the truck is on, it does show the status as charging the breakaway system battery.
I guess you could put a meter on the trailer battery with the truck off, and see if the reading increases when you start the truck. I don't know if it is a regulated 12v to the back, or a higher (alternator) voltage for charging.
Edited by Coastie
I hope you solved your issue by now. My fuse #63 in engine compartment for trailer battery looked fine, but still no 12v at 7-pin connector. I pulled fuse out, popped off it's cover and it is blown. Simply replacing the 30 amp fuse restored 12v at trailer connector, even when truck is off.
    daveishi
    daveishi
  • Who's Online   1 Member, 0 Anonymous, 826 Guests (See full list)
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
