No, they claim they do not make special fluids for racers, its the same fluid they sell to anyone.   What so hard to believe that certain lubes perform better than others.
They do....I just gave you the link to the AMSOIL Race ATF.
:nonod:
Wrong question. Certain fluids do perform better than others. Both AMSOIL and Red Line make PAO/Ester fluids that are far better than a Group III "Synthetic" but both companies also make heavier fluids for Racing. Red Line actually makes several depending on the heat it will see. ALL are PAO/Esters. Viscosity matters and the OEM spec 6 cSt @ 212 F is far from enough for 350 F.  Sir I have 40 years in the oil/gas/chemical business. I've made the stuff....
Question is why do you believe race trucks use stock parts and fluids specifications. Fact is he told you it wasn't stock!
That box wouldn't last 20 minutes with the OEM spec fluid in it at those temperatures sustained. If they say it (A 6 cSt fluid) ran for hours over 350F and looks like new...Liars.
    tararebecca
    tararebecca
  • Who's Online   3 Members, 0 Anonymous, 660 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
