Hello all, apologies if this is in the wrong area.
I bought a 2018 1500 LS double cab 4x4 used.  I noticed I have no traction control on the rear wheels yet no lights are lit on the dash.
I can cycle the stuff off and on by pressing the button, but when the lights are off traction control still doesn't seem to be working.
Do I need to try a scanner?
Welcome to the site.
Check for the fuse to see if it is still in the under hood FB. If it is present (some people take them) make sure it is good.
Just a guess as where to start.
48 minutes ago, Lftwfls said:
I don't see any fuses labeled as TCS
Check #3 and #25, once again, this is just a guess, hoping to save you a trip to the dealer and some money.
Traction control can not be tuned out. The button on the dash still has to be pressed to turn it off completely.
I can burn rubber with traction control still on just a fyi. It really start to act up if it wet out or snow on the ground because the wheel speed increases much faster and it kicks in.
I will check those fuses first thing in the morning. It only rains once every 6 months here so its usually not an issue, but the tires were waaaaaay too easy to spin today. I have not lit them up and kept em spinning to see if something kicks in later. I will try tomorrow.
It only rains 6 months a day here in Seattle (think about it), if it were working, you would know.
Took off from a stop light yesterday, the "nannies" kicked in, truck fell on it's face. Thought I had a Bow Tie impression from the steering wheel  on the side of my head as I went forward at 3 or 4 G's when power was reduced to stop wheel spin.
Edited by JimCost2014
  • Haha 1
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
