After seeing that the 2022 Ford F-150 isn't going to be that different than 2021, I am looking at the GMC Sierra and the website says I could reserve the 2022... but wouldn't that be at MSRP? I don't want to commit $100 to it and then be stuck at that deal.
I've been spoiled by the $10k off my RST when I bought it in 2019 and it held its value very well, so well that I can actually afford the $60k Denali. I know I won't get $10k off but I am hoping I could get around $4k off through GMC promotions (not from the dealership). That being said, should I call the dealership beforehand and negotiate how much off MSRP (separate from GMC promotions) before committing myself to purchase the 2022 Sierra?
With all the pent up demand, I think we will be paying MSRP for quite a while. There may even be dealer markups coming soon. I've actually seen markups for 2021s on the west coast. That being said, yes, talk with your dealer.
Edited by reeseb
Yeah I don't think you will be able to talk anyone down but it absolutely does not hurt to call and ask!
They did that reservation game back when they introduced the new Camaro and as I recall people were driving them whilst those who reserved them were waiting months longer.   Note the disclaimer.
Quote
Participation does not guarantee delivery of any vehicle within any particular time period.
That's the answer I needed... I won't be doing it that way then. Besides, it's almost moot if I custom order it anyways.
That pretty much does it for me ... I won't be doing it that way then. Besides, it's almost moot if I custom order it anyways.
I am hoping my dealership will let me put the entire $50,000 on the credit card so I can get enough miles for a roundtrip to Europe. If I'm going to be paying MSRP, I want that option then.
I'll be doing that, thanks!
Paying to get on a 'prospect customer' list....
Anybody got inside info on which cab/box/trim combos will be available first?
Edited by redwngr
For $100? No, I'll just hit Autotrader and look up new trucks. if I can find 2021 Silverados at $3k off the MSRP, I'm sure same can be done for 2022 when it comes out. Maybe not $3k... but I don't want to be committed to just one dealership.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,307 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
