Hi I have a 2021 Silverado 1500 and I’m putting in a 3.5” rc lift and eventually will be doing new wheels probably 20x9 and bigger tires my question is will I need wheel spacers I’ve heard I might to clear the break calibers? Ive never had wheel spacers before so they are new to me any help would be appreciated
It depends on your wheel design and how much space there is from the hub mounting space to the backside of the spokes. I had to buy a 1/4" spacer to clear my aftermarket wheels. You can buy them for $20 a pair at Autozone or the like. They are just a 6 lug hole flat piece of aluminum you slip over the studs then bolt the wheels on. There's enough extra threads on the lugs you don't need to worry about any different lug nuts or anything.
Any reputable shop worth their weight in salt will be able to tell you if the wheels you want will fit properly or not.  when I ordered my Fuel wheels I initially wanted a different style than the ones I got and they told me right away they would not fit due to the calipers.
I have a 2019 GMC Sierra 1500 Denali with 20x10 Fuel Mavericks with a -18 offset on 33x12.5x20 tires.
Looking at other builds on the same truck with similar wheel/tire combos it said they didn't use spacers.
When i had my wheels installed it wouldn't fit becuase of the brake calipers. I ended up having to use spacers, needless to say I was a little bummed.
What I don't understand is how these other same trucks got away without using spacers on similar wheels and offsets.
Wheel spacers.....
I have far more experience with these than I ever wanted.
I was working on some today.
What I can tell you is that everyone has a different opinion about them. Whats safe, whats not, what works, what doesn't.
My opinion:
Make 100% sure that you use the correct torque specs recommended by the SPACER manufacturer, not the vehicle manufacturer, and not the spacer reseller. The spacer manufacturer.
Use Thread Locker (medium) or Locktite (medium) on the spacer to bub bolts.
Make sure they are hub centric and not wheel centric.
Don't ever buy used spacers. Always get new ones.
Once everything is installed, drive it for a day, and then pull the wheels. Re-torque spacers to the hub (minus 10 lbs of original).
Drive it for another day, and re-torque the wheels lugs (to original).
Too much wheel offset combined with too thick of wheel spacers will cause inner fender rubbing while turning.
There are different types of spacers. Each one has its advantages and disadvantages. Average cost is around $120 for 4.
wheel-spacer-h-r-track-black-30mm-per-ax
  • 2 years later...
Can you tell me what size and brand spacer you used. Any issues?
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
