My 09 sierra 1500 4x4 5.3 door ajar light kept coming on as well as the dome lights I did some reading and decided to replace the lock actuator. That solved the problems just to make a new one now the radio won't go off when you open the driver door nor will the dome light come on but passenger door will I have checked wires and any fuses that I thought may have been a problem help please this is driving  me crazy
That is all related to the door latch, not the lock actuator.
I'm also not sure if that can be replaced without programming. Got a 50/50 shot. Thank GM for that wallet-sucking brainstorm. 😡
Gotcha, forgot they're integrated these days. Like I mentioned, there's a good chance that new latch needs to be programmed to work correctly. I know if you replace just the door switches, those require programming, so it's not a stretch to figure the latch does, too. Nothing will work until that is done, if I'm not mistaken.
DO NOT go to the dealer for this! Find a private shop that has the capability - not all want the hassle, so you might have to search. Be sure to ask them up front if it is even needed, and don't rely on one shop's answer  - get a 10th opinion to be sure. I'm not 100% certain, but the way these trucks were engineered, I wouldn't be surprised if it is indeed required.
If that's not the issue, then you'll have to chase wiring and connectors. Pin fitment is also a big issue in the modern automotive world. Been lots of poor fitting pins in connectors, either from rookie techs jamming things in them for testing purposes, or from low-bidder Chinese crap parts quality.
That's all controlled by the BCM, but the locks are controlled by either the key fob or door switch. The RAP is controlled by the latch internally.
Could have got a bad one - that's always a possibility, especially these days. I'd make sure the wiring and connections are good first, though.
    • We've done a bunch of them.  Very common failure.  They don't sell the park position switch separate from the shift control assembly which is stupid, because they ended up selling a switch on some other products like 2016-2019 Malibu, 2018-2019 Traverse, 2019 Blazer, and another car or two as those were having the same issue for years (but these have a console mounted shifter not column mounted).
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
