I've been looking at the one Rough Country has.  It comes with a new lower valance and led fog lights.  I only want the winch tray.  I've been weighing whether or not I'll buy it.  One area of concern I'm noticing is the tow hooks.
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
