So Here's the issue. If the back tire's spin "burnout" even slightly like if say it was wet out and I leave from a dead stop.
My truck 100% of the time will pull really hard to the right afterwards and one of the two rear tires will lock up and release over and over then randomly the truck will go back to being just fine.
I can hit big bumps, drive on the highway, do anything and its fine. I've checked the diff and put new fluid in. leafsprings are fine i can easly turn the tires by hand. no noises either.
any clues?? also when the truck pulls right its a way harder pull then just a draging tire.
This very issue was posted by another new member to the site about a week ago. He claimed missing bolts in the front suspension.  I guess follow his lead since it seems both of you experience it with random bumps, and "Burnouts"
locking diff or open? any noise from the differential? possibly bad spider gears. pull the cover and take a look. have you checked to see if theres oil in the diff?
It was posted by this same exact new member
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 294 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
