I have an intermittent problem where my 2000 year 2500 6.0l won't shift out of 1st gear on acceleration.  Just before this happens the dashboard display lights flicker once or twice.
97% of the time the truck shifts great - no tranny problems.  It seems it is an electrical issue but my local dealer is stumped.  He has only put one hour into it though.  Not sure I want to go digging at $140 per hour so I thought I could ask the forum for help....Thanks
BCM Ground. Driver side CAB Extension mount ( just under the DS door) On the mount, facing rear are a bunch of wires
grounded to the mount. Remove, clean WELL, then grease/woolwax  after re installing.
Cost... about Free...
Still have issues? Grounds at back of engine to Firewall..
Edited by Formulabruce
    • It really is comical when people don’t agree or see the reason some people prefer the older vehicles. They become condescending. All the while they may be busting their knuckles on old vehicles. I have found memories of swapping out engines in my old GM cars in a weekend without much hassle. Unlike today. One wrong move a computer will shut you down. Even on something as easy as a brake job. There’s a pretty comical YouTuber called the car wizard. A garage owner who puts it all in perspective. Another Vicegrip garage that’s shows just how tough the old stuff is.
