I bought a Redtiger dash cam, front and rear camera.
My truck did not come equipped with the third taillight camera, so I bought a new third taillight that has the factory camera installed hoping I could just wire up the factory camera to the redtiger dash cam.
Does anyone know if the factory camera wiring can be matched up to the redtiger or any aftermarket camera?
If this is not possible my alternated is to install the redtiger camera in the factory camera taillight.
Any input would be helpful.
I have a Silverado 1500 LTX and he has front and rear cameras (as well as several others). Does anyone know if the video from these can be saved or exported, to serve in place of adding a dash cam?
Anything is possible with the right amount of money
    • Looks nice. I still have my 2000, 1500. Bought a 2025, 1500 for retirement. Feels solid. These trucks have a bad rap on the internet. My brother has a `24 1500, 5.3 with 52,000 miles. No problems at all. Mine hasn`t either but mine`s only at 12,700 miles. Have seen some of these things with 100,000 miles with no problems.
