2006 Chevy Silverado with 4.8L V8. Daughters truck.
She calls and says the truck is revving but hardly moving then if she turns off the engine and starts again it runs fine for a minute or two and then goes into 'limp' mode and then like it is in neutral.
I put a code reader on and it had some codes. I cleared them and then was left with MAF sensor issue and oil pressure sensor failed. Replaced the MAF sensor. Still have problem.
Someone suggested the ignition switch so I replaced the ignition switch module (not the actual key part). Still have problem.
Transmission fluid is up, looks and smells fine.
It also does a strange thing when reconnecting the battery - the engine tries to start and dies on its own 3 times - scary when it happens!
Help please...
When you reconnect the battery, it tries to start by itself 3 times in a row? That sounds like you have an OEM or aftermarket remote start system that is not working properly. You may have a bad "computer". I would not replace any more parts without having a diagnosis. Its easy to spend $500 on parts that don't fix the problem, and a diagnostic only costs $100. What ever parts you put on, take them back off and return them if they didn't solve the problem. Then take that money and pay the dealer or a GOOD local shop to do a 1 hour diagnosis - just to see what they can come up with.
Edited by Supreme Pizza
Thanks.  I think it is an aftermarket auto starter and it did have an alarm system installed as well. We don't use either of those but there is some wiring under the dash associated with those systems.
The truck was one my company trucks that got passed on to the kids - so had it for a long time, almost since new. It was running rough and some of the original codes were to do with tht  The new MAF sensor fixed that.
My guess is that it is the main ECU but I have a diagnostic code reader
Having trouble typing replies on this site... really bad lag.
I have a good diagnostic code reader with Bluetooth connection to iPhone app. No codes from any modules. I have the oil pressure sensor which I will change out but it is in a hard to reach place. I can't see that causing the problem but the gauge doesn't work so it is worth replacing it.
If your oil sender is like mine, then you need a large socket, a swivel, a ratchet, and some extensions. A mirror and flashlight help too. Its worth wearing light gloves and long sleeves to keep from getting scratched up when your reaching back there.
Its easier to change the oil sender if you pull the intake, which is not hard at all - but it is probably more time consuming to do it that way.
Thanks for the late advice...I was feeling around in the area a couple of days ago and now have scratches from knuckles to half way up my forearm!
I have all the tools and the 1-1/8" deep socket but waiting to change the sensor.  I need to get the running problem figured first.
Ive had/have lots of GM vehicles and never experienced a 'limp mode' with any of them.
My only experience with that mode was in my Mercedes Sprinter van RV with turbo diesel going over the Coquihalla highway pass coming out of Vancouver. Minor issue but a big tow bill!
For the limp mode, since its accompanied by an oil pressure issue, I would normally say that it could be an AFM issue - but I do not believe that your year/ engine size came with AFM as an option. However, since the gauge is not reading anything, are you sure that you are in fact building oil pressure? Also, what happens if you drop it into the 4x4 low range? Is it able to drive around in that mode?
The oil gauge is pegged at high. Diagnostic said the oil pressure sensor was "shorted".
I've tried the drivetrain in forward, reverse, 3,2,1, 4WH and 4WL. I thought maybe the torque converter but that was eliminated from the driving tests.
I'm not a mechanic but grew up fixing what I drove.(1963 Ford Fairlane 2 door Sports Coupe was my first car) Dad was a petrolhead in England and would build full cars from bits and pieces after the war. I have an electrical contracting company now.
Jack of all trades...master of some!
What surprises me is that I've talked to a mechanic and a transmission rebuilder and now posted here and nobody seems to have heard or seen anything similar happening to a GM truck.
The exception being a brother-in-law who had similar happen to him and the fix was the ignition switch.
ok sorry I didnt see this post earlier, or read it but, I see you say you changed the maf.  Why didnt you change the oil pressure sensor?  If it is bad, sometimes your truck will think the oil pressure is too low, and will cause damage so will shut down, in your case go to limp mode.  When you change the Oil pressure sensor also test the plug, to make sure you have a good connection.
for a 5.3 the socket size is a 36mm and you will need a 3/8 ratchet extension 4 to 6 inch and also remove the plastic tb cover 4 bolts I think are 8mm. This is done by feel, but there are plenty of you tube videos on this.
Edited by Sharpz
Originally, I was thinking about the oil pressure issues shutting down the engine, but I have seen these motors run with 0 oil pressure for 15 seconds, with no automatic shut down. Not just a oil sender problem, but actually 0 pressure in the system. They just had warning on the dash. Is there a built in safety that will turn the engine off or at least some of the cylinders?
I haven't changed the oil sensor yet. It is in a bit of bad place on the 4.8L engine so I'm putting that off to last.
I have all the fluids to do the transmission and both front/back differentials now. will try to get to that in next 2 days.
I don't drive the truck so I don't know when the sensor/gauge started acting up. it is an input to the engine management system so maybe there is an output that causes these symptoms.
The baffling part is the engine revs to redline without an issue during this problem. I would have thought the ECU would have limited the engine revs in 'limp' mode and let the vehicle limp home.
Lets go over the symptoms again, if that's cool with you. There was some "he said she said" 3rd party stuff in the original post.
What are the exact symptoms, codes, and things you have already tried?
Okay, totally understand that. I think it comes down to 2 separate problems.
In the past few months the truck was running rough.
Pulling up to a stop the revs would go down and then surge causing the truck to move forward.
Daughter complained but nothing was addressed at the time.
Service engine light was on.
Last week she phones to say that the truck starts and runs but then won't move when in gear.
I have her bring it to the shop and put a diagnostic reader on and clear codes.
Codes were symptomatic type i.e. intake, combustion, exhaust out of range.
Cleared codes. Test drove it. All drive fine for 2 minutes or so and then acts like trans in neutral.
Codes that remain are MAF sensor and oil pressure sensor (shorted).
Replaced MAF sensor. Put injector cleaner in fuel.
Engine runs fine but after 2minutes it is all revs and no go.
Shut engine off. Start again. Runs and accelerates through the gears ok for about 2 minutes.
Repeats the same sequence over and over again.
So MAF was one problem which I think is fixed. Engine starts and runs smooth now.
Lack of motion after a couple minutes is the baffling conundrum now.
    KirbyCo
    KirbyCo
  • Who's Online   7 Members, 0 Anonymous, 1,442 Guests (See full list)
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
    • There's a bunch of tea leaves that you've read, but in any case the delayed timing is unusual. Not sure how that relates to the rich at idle vs. 'normal' while driving.   If you're in this deep, might be worth investigating, and re-learning the sensor. What have you got to lose? Plus, it properly fixes the timing cover leak.
    • The only problem I have seen this cause is longer crank times.
    • Injector is being sent off today for rebuild and I estimate I'll have it back in 10 days or so.   It may not be the injector...of course...now that I've torn down the intake again. But, let's rule out the injector and replace those spider legs that have been almost rubbed through.   The truck has always had negative timing and I'm reading "normal" timing at warm idle should be +16 or so. I'm negative 16 to 25 or more, and it's always been like that since I bought it.   A light turned on upstairs last night in the old noggin. Rare, I know...   This will be wild, if it turns out to be the cause!   In 2001, according to the old service documentation, the muffler was replaced. Why? I have no idea, it wouldn't have been rusted through by then. But they did a crappy job.   In 2019, another shop replaced it and noted the prior install was poorly done on the work order. "Exhaust system vibrates on crossmember". Except...I guess they just left it be? I believe the husband, the couple who were original owners, had passed by then. Maybe she said it's just not worth it to have the exhaust system fixed and declined repairs. Very few miles were driven between 2019 and 2025.   The exhaust system vibrates heavily on the crossmember and you can feel it and REALLY hear it, even today. Not always, but at idle, it gets going pretty good sometimes.   What if....   ....What if that's enough to trigger one or both of the knock sensors? Could it be tricking the sensors into sensing knock, so it's pulling timing aggressively? Pulling timing heavily means it's firing after the piston reaches full height which means incomplete burn which means the O2 sensor is sensing a rich condition, which means I've been chasing my tail, and what I thought was an inconsequential problem (janky exhaust) has been THE issue for this truck for 25 solid years?   That would be wild. Maybe it IS wild.   The service documentation thereafter, for years, shows visits for rough idle, replacing O2's, replacing the cat, replacing plugs and wires, a misfire condition, like they could never solve the issue. The injector has been replaced 4 times in 80k miles, that's just crazy.   The secondary theory....   The engine has clearly had a leak at the front seal for a very long time (the greasy trench...). I think the truck changed hands quickly ~2025 because there's Napa receipts from someone I don't recognize in the ownership history. They apparently replaced the timing cover seal, and they did a terrible job. There's RTV smeared all over and the leak I had reduced to a weep by snugging the front oil pan bolts is now a leak again.   HOWEVER....I read about replacing the crankshaft position sensor. Any time the ckp sensor is disturbed or timing cover is removed, the truck requires relearning, and that can only be done through a bi-directional scan tool. Skippy with the RTV probably didn't do the relearn procedure is my guess. His scan tool is lost in a pile of RTV goo somewhere.   So, it's very possible the sensor has been disturbed and the truck is just running on the old learn data but not setting a code for anything. The distributor has since been replaced and so has the camshaft position sensor, so all bets are off for that thing.   In the theme of one step forward, two steps back, I returned the accumulator for the AC. The gal I've been working with at O'Really's has been great. She refunded it under manufacturer's defect and we compared it to the replacement I ordered, and sure enough, the replacement is machined very differently (and a gauge actually fits on it!).   Got it home, installed it, started vacuuming it down.... and I couldn't get good vacuum.   The high side service port, where I replaced the old GM ball valve suspecting that was a source of the previous leak....well, I've clearly exposed whatever pre-existing crack in the line where the service port is welded, and made it much worse. Blessing in disguise? Except there goes another $25, now I'm waiting for a replacement AC line.   In 10-ish days ALL the parts will be here. Rebuilt injector, new exhaust system, new cat, new high pressure AC line.   Oh, did I mention the squeaking ISN'T coming from the AC pump? The truck still squeaks when started, and there were words after I started it with the new AC pump installed. But, there was more to replacing the AC pump for just a squeak. A truck with good working AC is something of value, for the comfort alone.   I've ordered a new harmonic balancer because, 30 years is a good run for one of those. Rule it out. The squeak may be something more sinister, though. I'm worried about that ckp sensor and if it was shimmed correctly, or if the timing set was installed correctly. The squeak may be coming from UNDER the timing cover.   At this point, once I get it put back together, I'm thinking I'll take a 50 mile victory lap and then promptly put it up for sale. This truck is cursed. Betty, from beyond the grave, doesn't want anyone messing with her Blazer. Or maybe she's getting revenge for 30 years of shop visits with that thing.
